what car ??
Posted: Tue Aug 14, 2018 2:29 pm
by shaunmelly
Hi all im new to the group (and rovers) I have puchased a 1935 Rover 10 saloon, can anyone tell me how much easier it is to drive the later P2 models as I have MS and its a bit too much for me.I am used to driving late 30s Austins and bubble cars but this car has me beat
thanks all for your comments
Re: what car ??
Posted: Thu Aug 16, 2018 3:46 pm
What issues are you having? Not a lot of mechanical difference P1/p2 so perhaps the problems you have are specific to your car rather than the model.
Good to hear more detail from you.
Re: what car ??
Posted: Mon Aug 27, 2018 8:03 am
by jp928
As an example, I have a 26 9/20 that was 95% restored by another, and I am trying to finish it off - all mechanicals done, apparently well, but needed wiring, trim , glass etc. As soon as I tried to get it moving under its own steam, I found the steering horrendously heavy. Bumped tyre pressures on advise, not much help. Started eliminating possible causes by selective dismantling. As soon as I disconnected the drag link, the steeing box was axcellent (a little slack in the centre), so the problem was not there. Drag link - one ball joint was the cause - done up far too tighly, and required heat to loosen the adjuster. Its much better, but still heavy - 1-1/4 turns lock to lock.
Tell us the issues you have so we can advise properly.
jp 26 Rover 9
Re: what car ??
Posted: Mon Aug 27, 2018 10:12 am
The crash gearbox is also a required skill, but easy enough once you get the hang of it and very satisfying! Again, if this is an area of concern we can give guidance on the technique required.
I saw a Rover 10 for sale- eBay I think- which sounded like yours. If that is the case I do hope that you share your issues with us before it sells, giving you the best chance of enjoying it while it’s in your possession. My pre war Rovers are a joy to drive and far better than many vehicles 30 years newer!
