Hi Stewart
I bought the clutch plate from Mike Evens, and while he was inspecting my old plate he had concerns over which plate to replace it with relating to thickness, we finally decided on a replacement plate with what seemed to be not overly thicker than the original but this did give issues as related
The pressure plate seems to be the correct thickness just the linings had a little more meat on them, the reason I made several packing pieces was to try different thickness until I got what I wanted and I would be able to adjust them as you stated if required
P2 Clutch problem
stuartbell
Re: P2 Clutch problem
Hi Mike,
Thank you for your reply. Between yourself and Luli, this has given me some food for thought, as I know that (from my initial inspection of the running gear on my '10) I am going to face this challenge - at least in part. Building-up the shims in stages, so they can be removed in stages (if desired) seems a valid enough fix if it means that pedal efforts are kept consistent throughout the life of the clutch linings. If I can get my clutch free, I shall have an experiment along these lines....
Regards,
Stuart
Regards,
Stuart
