Page 1 of 2
SU Carb
Posted: Sun Nov 04, 2012 5:15 pm
by SNOBHILL39
Has any member got some pictures of the SU Carb like the one I have fitted to my 47 12 tourer. There are some linkage pieces missing from the jet to the throttle spindle so when the choke is pulled out it does not open the throttle as is I believe it should.
Any help please.
Gerry
Re: SU Carb
Posted: Sun Nov 04, 2012 9:26 pm
by 47p2
I was under the impression that Rover changed to Solex carbs after 1930/40
Re: SU Carb
Posted: Mon Nov 05, 2012 6:43 am
by SNOBHILL39
Well someone put the SU on mine.
Re: SU Carb
Posted: Tue Nov 06, 2012 7:54 am
by lakesrally
Hi Gerry, I cannot help as I don't have a P2 but it might help if you can either post a picture of the carb you have at the moment as it might be the wrong one, or at least tell us which SU carb you have. According to the workshop manual you should have a Solex 30FA1, which might explain why noone has posted the picture you want.
Re: SU Carb
Posted: Tue Nov 06, 2012 12:54 pm
by jefflee
Hi, could you post a picture of your carb set up , is there a seperate hand throttle control ?
i think the su carb is the best. Jeff.
Re: SU Carb
Posted: Tue Nov 06, 2012 8:42 pm
by SNOBHILL39
Re: SU Carb
Posted: Tue Nov 06, 2012 10:23 pm
Maybe this can help:
(1937 Rover 10).
Re: SU Carb
Posted: Wed Nov 07, 2012 2:32 pm
by jefflee
Hi Gerry, you should have a hand throttle cable next to choke cable on dashboard which clamps onto the choke linkage on carb and is pulled to open throttle ,
also there should be a brass lever that pivots on the bolt screwed into carb and moves throttle linkage open slightly, Jeff.
Re: SU Carb
Posted: Sat Nov 10, 2012 2:17 pm
by GOY189
From the 1940 season, all Rovers were fitted with Solex carbs. The SU fitted to your car dates from 1939 or earlier. That said, SUs are generally easier to tune than Solexes.
Re: SU Carb
Posted: Sat Nov 10, 2012 8:52 pm
Up to car 6210056 (1946 model) SU carburattor had been available for Rover 12 . Page 16 on the master spare parts list says:
[img]
http://www.flickr.com/photos/linmagazine/8173087852[/img]
