Front hub seals
Axle
Front hub seals
Post by Axle » Mon Jan 31, 2011 7:24 pm
Hi, can anyone tell me the NA part number of the front hub seals for my 1938 12 p2 and would they be the same as the auntie range, cheers.
Re: Front hub seals
Post by GOY189 » Sat Feb 05, 2011 2:20 pm
Hello, Needed a little research to answer this one.
All models 1936 to 1960 (includes all drum braked P4s) used Rover part number 03429 that superceded to 235986. The Payen equivalent number I understand is NA239. (For intrerest Disc braked P4s and I suspect P5's use a thicker seal- NA525).
Full instructions for stripping, replacing and adjusting the hubs are in The P2 Workshop Manual published by the RSR. Usual Disclaimer applies.
Mike Maher
