Sunroof drainage
Sunroof drainage
Hi all. Can anyone tell me where the sunroof front rubber drain tubes exit the car. I've tried a " mole" using stiff cable but suspect it stopping at a blockage. How easy is it to replace ? - I assume it goes down the A posts - no sign of it in that area underneath car. Thanks Alan p3man 451
Re: Sunroof drainage
Under the front wings. There should be two pipes exiting there on each side, one from the front of the roof and one from the windscreen surround.
Thanks Stewart, There is no sign of these pipes . I need help as to their location, roughly. There's a lot of underseal on undersides of both wings. If you could point me in the rough area, I'd be most grateful. Do you know if rear and front windscreen seals are available from anyone? Thanks for your time . Alan p3man451
I'll get a look at the car and take some photos, maybe tomorrow as the car is not at home. Windscreen seals were available from Mike Couldry and I suspect that Mike Evans may have dealt in the too, I would try them first.
Try http://www.scottsoldautorubber.com.au/R ... 948-49.htmp3man451 wrote: Do you know if rear and front windscreen seals are available from anyone?
