				Vacuum Advance Mechanism components
				Posted: Thu May 21, 2020 9:31 am
				by Ray
				Does anyone have a picture of the Vacuum Advance Mechanism components on the 1949 Rover P3 distributor.
				Re: Vacuum Advance Mechanism components
				Posted: Thu May 21, 2020 3:02 pm
				by GOY189
				Would that be a Rover 60 or a Rover 75?   4 cylinder cars (Rover 60) use  part 261489 - same as Series 1 Land Rover
				Posted: Thu May 21, 2020 3:38 pm
				by Ray
				Hi, thank you for your response.
It's a 75
Regards, Ray
				Posted: Thu May 21, 2020 4:26 pm
				by GOY189
				The P3 75 vacuum advance is Lucas part 424625 according to the Lucas distributor cataolgue.  If you are looking to obtain one, can I suggest the distributor doctor in the UK?
 Best regards
				Posted: Thu May 21, 2020 4:55 pm
				by Ray
				I have the parts for the mechanism but I am not sure how they go together.
I am after a picture or exploded view of these parts as they would be if you could see inside the barrel of the distributor.
There is a heavy spring, a light spring, one hollow piece of brass, one solid piece of brass, a thumb screw assembly and the diaphragm.
There were also five washers under the large nut which screws into the Diaphragm Housing but I don't think they were supposed to be there.
The Distributor Doctor said he doesn't have a picture.
I hope this makes sense.
Regards.
Ray Lilly
				Posted: Fri May 22, 2020 5:58 am
				by MaxPegler
				Have you got the RSR Parts Manual. there's an exploded view in there that should help.
Max P
				Posted: Fri May 22, 2020 7:16 am
				by Ray
				I have the RSR Manual but I can only find the exploded view of the distributor on Page J4.
This does not show the detail of the parts I mentioned previously.
Please let me know the page number if I have missed the exploded view you are referring to.
Regards,
Ray Lilly
				Posted: Sat May 23, 2020 11:20 am
				by GOY189
				Hi I can't find the exact model but there are plenty of exploded diagrams on the net .
There are  general views of Lucas distributors
here:-
https://www.uniquecarsandparts.com.au/h ... istributor
and here
https://mossmotors.com/mgb-25d4-distributor-1962-74
Hope this all helps
