Another P3
Re: Another P3
The jet should be home in it's carrier, which should be home in the body of the carb. You are talking about just one jet here, is the car a 60?
Re: Another P3
The car is a 75 so has 2 jets in the carburettor - I have sent the carb off for a rebuild using new emlusion tubes (made in brass) from Gower & Lee.
Does anyone have a photograph of where the timing mark is on the bellhousing for the gearbox? There seems to be a sort of rough V - but I'm not sure that I am lining up with the correct place - any tips please? Still haven't managed to get the car running well enough to submit it for a roadworthy test...........................
Thanks Neil
Thanks Neil
Re: Another P3
I tried Gower & Lee for a pair of brass tubes a while back for another member but got nowhere, I'll maybe give them another try. I am not at home just now but I will be getting the P3 out of it's barn when I get back the weekend after next, I'll try to remember to take a photo for you.
