Richard Clements 827Si - image heavy
Richard Clements
Re: Richard Clements 827Si - image heavy
Post by Richard Clements » Thu Oct 16, 2008 8:39 pm
evfe
Last edited by Richard Clements on Thu Mar 26, 2009 9:39 pm, edited 1 time in total.
Richard Clements
Post by Richard Clements » Sat Oct 18, 2008 12:07 pm
k
Last edited by Richard Clements on Thu Mar 26, 2009 9:38 pm, edited 1 time in total.
Richard Clements
Post by Richard Clements » Sat Oct 18, 2008 3:50 pm
Richard Clements
Post by Richard Clements » Sun Oct 19, 2008 11:12 am
dash.
richard moss
Post by richard moss » Sun Oct 19, 2008 1:16 pm
I suspect that the fuse had blown because it had seized.
I would start by removing that drain tube and squirting a load of WD40 (or other penetrating oil) in there and leaving it a few days, having propped it up in such a way that the oil runs down into that bottom bearing. You may find that this is enough to free it off (beware of trying to rotate it by hand before the oil has soaked in because the bearing can pull away from the motor body). Dismantling is OK but a bit fiddly as you need 3 hands to put it all together.
1990 827 Sterling manual
Richard Clements
Post by Richard Clements » Sun Oct 19, 2008 2:53 pm
richard moss
Post by richard moss » Sun Oct 19, 2008 7:59 pm
Looking good Guv'nor.
Richard Clements
Post by Richard Clements » Sun Oct 19, 2008 9:01 pm
richard moss wrote:Looking good Guv'nor.
Thanks Rich. :geek:
The Flying Dutchman
Post by The Flying Dutchman » Mon Oct 20, 2008 1:53 pm
That's a very likeable car. 8-)
Job.
'73 P5B Saloon
'96 220 Coupe
'97 820Si
'96 Triumph Herald 12/50
'96 Triumph TR6
Richard Clements
Post by Richard Clements » Sat Nov 01, 2008 1:56 pm
Hi All,
J
Last edited by Richard Clements on Thu Mar 26, 2009 9:40 pm, edited 1 time in total.
