Hi All
I joined the RSR in 2007 when I started the renovation/modification of the P3. Progress has been painfully slow but I have just got to the point where I have re-assembled the front suspension and need to tighten the joint pin nuts.
Unfortunately there seems to be some confusion here. At one point in the P3 Workshop Manual, it is stated that the nuts should be tightened with the top links in the central position to prevent strain on the rubber bushes and this seemed to make sense. However, at another point it states that the nuts should be tightened with the suspension in the static position. I set it to the static position but this did not bring the top links to the central position. Instead they were very close to the rebound position which did not seem right.
Is there anybody who knows the correct tightening procedure?
Many thanks
Roy Champion
Rover P3 front suspension bushes
modREPM795
Jump to
- General Discussion
- ↳ RSR Discussion
- General Information
- ↳ Forum dos and don'ts
- ↳ Adding Pictures
- ↳ New members
- ↳ Rovers Spotted
- ↳ Meetings, Rallies and Events
- ↳ I want and I 've got..
- Rover Vehicles
- ↳ Rover History
- ↳ Rover bicycles and motorcycles
- ↳ Archive
- ↳ Veteran/Vintage Rovers
- ↳ Archive
- ↳ Wilks' cars P1 and P2, thats cars up to 1947
- ↳ Archive
- ↳ Early post WWII, P3 the original Rover 75 and 60
- ↳ Archive
- ↳ Rover P4, the next 75 and all the variations
- ↳ Archive
- ↳ P5, straight 6s and V8s
- ↳ Archive
- ↳ P6, rover 2000s and 3500s
- ↳ Archive
- ↳ SD1, Rover with BL, what a combination
- ↳ Archive
- ↳ Rover 800, all doing a sterling job
- ↳ Archive
- ↳ Rover 100, 200, 400, 600, 25 and 45 inc Tomcats and Dropheads
- ↳ Archive
- ↳ Rover 75, the latest and last
- ↳ Archive
- ↳ The Specials, Maurauders,convertibles,Pininfarina,Graber, Kitcher and ...
- ↳ Archive
- ↳ 4WD, from pre-production to latest RR
- ↳ Archive
- ↳ And those not mentioned above ..
- ↳ Archive
- RSR The Rover Sports Register
- ↳ Club Information
- ↳ Freewheel, comments and contributions
