freewheel P4 75
KeithPearson
freewheel P4 75
Post by KeithPearson » Sat Jul 07, 2018 10:24 pm
I have a 1957 75 , and I don't think the free wheel works. The wheel turns ok, but I don't even know what to expect. Is there a cable that operates it and can it be seen underneath? is it worth even using?
Phil - Nottingham
Re: freewheel P4 75
Post by Phil - Nottingham » Sun Jul 08, 2018 8:03 am
The cable can be seen - they do sometimes seize from lack of use. It's easy to check if it works as on the overrun when FREE there will be no engine braking and you can change gear up or down without pressing the clutch.
I think they are great and use the one on our P2 all the time - except down steep hills
Your brakes need to be in good order
KeithPearson
Re: freewheel P4 75
Post by KeithPearson » Sun Jul 08, 2018 10:58 am
thanks, the previous owner never used it. Do you engage stationary or when moving? I see the point about brakes, engine braking could be really useful in mountainous Wales.
Phil - Nottingham
Re: freewheel P4 75
Post by Phil - Nottingham » Sun Jul 08, 2018 6:09 pm
You engage it when stationary = FiXED
Re: freewheel P4 75
Post by luli » Mon Jul 09, 2018 7:47 pm
Or when the engine is pulling - both engage or disengage. The reason is that when pulling both parts of the freewheel are stationary relative to each other.
KeithPearson
Re: freewheel P4 75
Post by KeithPearson » Mon Jul 09, 2018 10:04 pm
Thanks, but I still can't get it to work. I will try to crawl under and look at the cable.
KeithPearson
Re: freewheel P4 75
Post by KeithPearson » Wed Jul 11, 2018 1:32 pm
I have fixed it, there is an adjusting nut behind the wheel mount, screw out until hardly any play. works beautifully now.
Phil - Nottingham
Re: freewheel P4 75
Post by Phil - Nottingham » Thu Jul 12, 2018 6:17 pm
Well done and thanks for the update. Do you like it? Few do!
KeithPearson
Re: freewheel P4 75
Post by KeithPearson » Thu Jul 12, 2018 6:58 pm
well, it is a weird feeling and like nothing ever I experienced before, it will take some getting used to. The brakes get a real workout and round here , it is all hills.
jp928
Re: freewheel P4 75
Post by jp928 » Sat Aug 18, 2018 7:50 am
Put an Overdrive on it. I had a 50 P4 , with a P3 box (floor change), home made cover, and a Laycock overdrive fitted. Absolutely superb! Also a 90 grille!
jp 26 Rover 9, previously P2,P3,P4,P6,P6B,RR,Discos
