Possible regulator Issues
IanPatt
Post by IanPatt » Thu Feb 07, 2019 6:09 pm
Hi
Would any one be able to advise on a minor electrical Issue? My 1937 Rover 10 (Jenny) appears I think, to be suffering from a regulator issue in so much as it now takes around 40seconds or so for the ignition light to go out. On starting from cold (normally a week or but starts on the button) the ignition light remains on regardless of revs, gets brighter and eventually goes out during which time the ammeter does not move. After this it is fine and shows no issues and charging appears to be occurring; battry is fine and belt is tight etc.
Would the coil be going week or is there a maintenance regime on the regulator that needs to be completed??
Any help would be appreciated
Ian P
Phil - Nottingham
Re: Possible regulator Issues
Post by Phil - Nottingham » Sun Feb 10, 2019 7:41 am
The regulator points may need cleaning - cardboard with a little alcohol on it is best. Are there signs of oxidation on the points? It's well worth cleaning all the connections
IanPatt
Post by IanPatt » Mon Feb 11, 2019 8:02 am
Hi
Thanks for your response.
All cleaned up and reset the contact gap. All working fine.
Do you think the issue would have damaged the coil at all??
Your help is appreciated.
Ian P
Phil - Nottingham
Post by Phil - Nottingham » Mon Feb 18, 2019 11:45 am
Possible but unlikely as it seems OK leave it and wait see
IanPatt
Post by IanPatt » Sun Feb 24, 2019 9:24 pm
Hi
Apologies in the late response.
Thanks for your help on this one.
Jenny starts on the button and all is well.
Thanks again
Ian P
