I require a pair of REAR SPRING SHACKLES ( Pt. no 41326 which is made up from the Shackle 01337 and the bush 01339 ), the bush is easy to produce. I also require a 2-WAY TAP ( 59126 ) for the petrol tank and the EXTENSION PIECE ( 58777 ) which is a rod that screws into the tap and protudes through the back of the car with a brass knob on the end, this is pulled to select main/reserve. Can anyone help ? I have a couple of spare starter motors, and a couple of boxes of other original bits. Ask if you need help ? Thanks
Chris Dancey
Parts Required for my '10' Saloon Rebuild.
chris dancey
chris dancey
Re: Parts Required for my '10' Saloon Rebuild.
Thankyou, the parts I require have come my way, this site really does work. The work continues !!!
Glad to see you are getting the bits and pieced required for your lovely Rover Chris. I look forward to seeing her when she is completed
chris dancey
Thanks John, Bare chassis is being shotblasted, zinc coated and painted this week....let battle commence.
