Whining noise when I put lights on
edthebad
Post by edthebad » Mon Feb 06, 2012 8:54 pm
Hi there,
1997 Rover 216 Cabriolet
Sorry if this has been asked before but I have tried searching and surfing and can't find anything similar. I have a whining noise coming from what seems like the ECU which is only there when I put the lights on. Further more my rear and front side light has blown after being replaced so not sure if the two things are related. Any help or advice would be much appreciated.
Edward
Re: Whining noise when I put lights on
Post by 47p2 » Tue Feb 07, 2012 9:15 am
Sounds like it could be a poor earthing problem
edthebad
Post by edthebad » Sat Feb 11, 2012 11:08 pm
Turned out it was the nearside headlight adjuster motor just continually whirring round. Considerably cheaper fix. The light problem was a fuse and with the fuse out the motor kept whirring bizarrely. Anyway, thank for your suggestions.
Ed
Post by 47p2 » Sun Feb 12, 2012 7:30 pm
Glad you sorted it and thanks for letting us all know what the fault was
