p2 reverse gear
Vince
p2 reverse gear
Post by Vince » Thu Feb 12, 2015 7:02 pm
Hi folks.
Just got the engine and box back in my 37 rover 12 and no matter how I adjust the gear selector I can't get it to stay in reverse.
All other gears select well.
The detent ball and spring seem fine.
Any thoughts?
1938 P2 14
Re: p2 reverse gear
Post by 1938 P2 14 » Thu Feb 12, 2015 7:12 pm
Will it drive backwards if you hold it in reverse?
Vince
Re: p2 reverse gear
Post by Vince » Thu Feb 12, 2015 8:52 pm
The car isn't driveable yet but reverse does seem to engage when the lever is held.
Will have a look tomorrow to see if the output flange turns when the engine is turned.
Re: p2 reverse gear
Post by GOY189 » Fri Feb 13, 2015 12:32 am
Have you seen the gearbox gremlins post below? That might give some clues
Best regards
Re: p2 reverse gear
Post by luli » Fri Feb 13, 2015 2:18 pm
Observe the following picture: Image
(right click and select 'view image' to fit it to your screen).
Open the gate cover (#66). #51 is the reverse selector. Put the gear lever in neutral, and using a long screw driver push #51 backwards. If you hear a click and it is locked than the gear lever adjustment is in-correct – not reaching far enough. Probably The change speed gate assembly (#20 in the next picture) is not in the right position. Note that its position can be adjusted.
If it goes all the way and does not lock the spring 49 (in the first picture) may be weak.
Vince
Re: p2 reverse gear
Post by Vince » Fri Feb 13, 2015 6:57 pm
Thanks for the replies.
Had another look tonight and it was the plate beneath the gear stick. Adjusted it rearward and it is now working.
Thanks again
