Help, how does my 14 dash come out?
Arewethereyet
Post by Arewethereyet » Tue Sep 15, 2015 3:03 pm
Hi all, my ignition switch is spinning round and the solenoid wires adrift! I've removed the 4 nuts that appear to hold the instruments into the dash but the cluster is still being held. How do I get the cluster out without removing the whole dash!
Re: Help, how does my 14 dash come out?
Post by GOY189 » Fri Sep 18, 2015 8:50 pm
The ignition switch is held in by a wire clip that is fastened with a small nut and bolt. Loosen the bolt, slide the clip backj and you should be able to pull the ignition switch out without removing the dash
hope that this helps
Arewethereyet
Post by Arewethereyet » Sat Sep 19, 2015 10:56 am
Many thanks Mike, that's it sorted.
