Rover P4 Radiator Muff
Roverman
Post by Roverman » Sat May 20, 2017 4:32 pm
I have just managed to get my hands on a radiator grille muff for my P4 110.
Would anyone be able to tell me how it is secured to the grille
Many thanks
Phil
Some where Rover the rainbow
Re: Rover P4 Radiator Muff
Post by GOY189 » Fri May 26, 2017 5:11 pm
Phil. I suspect that it is fastened using the sort of fittings that are used for grille fitting badges, but cannot be certain. -Bar drilled and tapped at the centre with appropriate long bolt/ setscrew.
Roverman
Post by Roverman » Fri May 26, 2017 7:10 pm
GOY189 wrote:Phil. I suspect that it is fastened using the sort of fittings that are used for grille fitting badges, but cannot be certain. -Bar drilled and tapped at the centre with appropriate long bolt/ setscrew.
Hi Mike,
Thanks for that info, much appreciated
Phil
