freewheel P4 75
freewheel P4 75
Postby KeithPearson » Sat Jul 07, 2018 9:24 pm
I have a 1957 75 , and I don't think the free wheel works. The wheel turns ok, but I don't even know what to expect. Is there a cable that operates it and can it be seen underneath? is it worth even using?
KeithPearson
Re: freewheel P4 75
Postby Phil - Nottingham » Sun Jul 08, 2018 7:03 am
The cable can be seen - they do sometimes seize from lack of use. It's easy to check if it works as on the overrun when FREE there will be no engine braking and you can change gear up or down without pressing the clutch.
I think they are great and use the one on our P2 all the time - except down steep hills
Your brakes need to be in good order
Re: freewheel P4 75
Postby KeithPearson » Sun Jul 08, 2018 9:58 am
thanks, the previous owner never used it. Do you engage stationary or when moving? I see the point about brakes, engine braking could be really useful in mountainous Wales.
KeithPearson
Re: freewheel P4 75
Postby Phil - Nottingham » Sun Jul 08, 2018 5:09 pm
You engage it when stationary = FiXED
Re: freewheel P4 75
Postby luli » Mon Jul 09, 2018 6:47 pm
Or when the engine is pulling - both engage or disengage. The reason is that when pulling both parts of the freewheel are stationary relative to each other.
Rover 12 1947 tourer (in restoration)
Re: freewheel P4 75
Postby KeithPearson » Mon Jul 09, 2018 9:04 pm
Thanks, but I still can't get it to work. I will try to crawl under and look at the cable.
KeithPearson
Re: freewheel P4 75
Postby KeithPearson » Wed Jul 11, 2018 12:32 pm
I have fixed it, there is an adjusting nut behind the wheel mount, screw out until hardly any play. works beautifully now.
KeithPearson
Re: freewheel P4 75
Postby Phil - Nottingham » Thu Jul 12, 2018 5:17 pm
Well done and thanks for the update. Do you like it? Few do!
Re: freewheel P4 75
Postby KeithPearson » Thu Jul 12, 2018 5:58 pm
well, it is a weird feeling and like nothing ever I experienced before, it will take some getting used to. The brakes get a real workout and round here , it is all hills.
KeithPearson
Re: freewheel P4 75
Postby jp928 » Sat Aug 18, 2018 6:50 am
Put an Overdrive on it. I had a 50 P4 , with a P3 box (floor change), home made cover, and a Laycock overdrive fitted. Absolutely superb! Also a 90 grille!
jp 26 Rover 9, previously P2,P3,P4,P6,P6B,RR,Discos
jp928
Return to Rover P4, the next 75 and all the variations
Who is online
Users browsing this forum: No registered users and 0 guests
