Brake fluid reservoir
OldFogey55
Post by OldFogey55 » Wed Aug 22, 2018 5:25 am
Folks, this is a two-part question.
I have a 1951 P4 75. I have a parts book only for a 1954/1955 P4 (ie third edition).
For the brake fluid reservoir, the part book shows the following components:
- SUPPLY TANK ASSEMBLY (ie reservoir) part 233206
- Filler cap for supply tank part 260819
- Gasket for filler cap part 260820
Question Part 1 - can anyone with a 1951 parts book confirm that the parts numbers are the same?
Question Part 2 - can anyone recommend/identify a supplier in the UK from whom I could source these parts? (I'm coming to the UK in November, so I aim to pick up the bits then)
Henry
1951 P4 75 - Delilah
Re: Brake fluid reservoir
Post by GOY189 » Wed Aug 22, 2018 6:51 pm
As regards part numbers, yes, But... the Master parts list (19th edition) gives the part number supercessions and 233206 supercedes to 271581 (Series1 or 2 Landrover brake fluid tank)
These are a common Girling part and there are plenty about, although they are most likely new reproductions. For brakes, a new tank is preferable to a new old stock item imo.
John Craddock of Cannock, Staffordshire and Dingocroft of High Wycombe will both supply a tank with lid/ gasket.
see:- https://www.johncraddockltd.co.uk/searc ... &sb=Search
and https://www.dingocroft.co.uk/acatalog/S ... ml#a271581
also John Wearing https://www.johnwearingp4parts.co.uk/pr ... rod=271581 He will also supply the correct transfer or sticker for the tank.
Hope all this helps
OldFogey55
Post by OldFogey55 » Wed Aug 22, 2018 11:43 pm
Mike, Thank you
Henry
