P4 90- too short axle ratio
Postby MisterEnderby » Sun Oct 07, 2018 8:18 am
Hello, in addition to my Wolseley 14/56 from 1936 I like to buy a Rover P4 to tow my pre-war caravan even on longer distances and on the highway.
Yesterday I made a testdrive with a 1956 P4 90- the car was in quite good order and drove fantastic, but I was confused that from 33mls/h on the engine was to be heard working, from 45 mls/h it was heard to be working very hard- I could not imagine and even would not try to get the car driving more than 60mls/h without feeling of tortouring the engine.
I am used to that standard with my prewar cars and even heared about the short axle ratio with the P4 , but expected the Rover to drive about 50 mls/h with adequate silence.
The vendor offered me a 1:3,91 diff on top for free, but before buying the car I would like to know:
-are all 90s have a freewheel fitted (in the tested car it was not engaged and I even have not seen a knob under the dashboard)?
-will a 1:3,9 diff solve my problems
-will a 1:3,54 diff maybe the better option or does it make the car too lazy
-would bying a later gearbox with overdrive without changing the diff even an option
and at last a different question:
are there aftermarket chrome bezels to put around the instuments availiable? Would like to have a bit more blig-bling on the dashboard.
Regards from german baltic sea
Brian
MisterEnderby
Re: P4 90- too short axle ratio
Postby Phil - Nottingham » Fri Oct 19, 2018 9:44 pm
1956 models did not offer freewheel - fixed was standard with axle ratio 4.3 : 1. Overdrive was optional. The 3.9 : 1 was used on 55 models which had freewheel as standard.
I am surprised you think its over-reving and noisy as our 100 has a 4.3 : 1 rear axle and in top without overdrive engaged is quiet enough even at 70 mph
Perhaps you need to check what axle ratio you actually have by turning the wheel 2 turn (with the other wheel on the ground) and counting how many turns the prop shaft moves. It may be it already has the 3.9 : 1 diff?
A box with overdrive would be better if it does have the standard diff.
Rover did not do bling really especially in the mid 1950's. No different bezels are required!
Return to Rover P4, the next 75 and all the variations
Who is online
Users browsing this forum: No registered users and 0 guests
cron
