Electrical issue
kevh
Electrical issue
Post by kevh » Mon Aug 08, 2022 12:44 pm
Hi All,
Finally getting to the back end of my 1935 12 restoration and have a problem. Electrics are not my strong point and I did a quick run through to see if everything was working ok, everything worked as it should until I got to the traficators, the right hand worked fine but the left hand flicked out and I then lost power to the panel which holds the switches for the indicators and traficators and no ignition lights. I have checked the two fuses behind the dash and they are ok but there is no power to them, any suggestions?
1935 Rover 12
