Post
by chris dancey » Sun Apr 29, 2012 6:02 am
All the previous information is correct. The P1 ' 10 ' D Back Saloons did not have a wooden frame, the body is made up of many sections with wooden parts for attaching trim, fitting etc. and a kind of twisted cardboard pushed into some of the cavities for the same purpose , the main bodyshell was initially in three pressings, left, right and the piece in the middle from the sunroof down the back..all welded together and lead loaded to hide the joins.
I have made the replacement sill / threshold side panel by hand and mig welded in without too much problem.
Having two ' 10s ' 1935 models, I can say that both are different in details, my first one is a late 1934 and the second is a late 1935 model ( both '35 models ), they were obviously hand made as the panel fits are not that good and there are obvious differences. I am making panels at this moment by hand but I am only using the originals as a template guide, I use cereal packets to make templates that give a much better fit. On Snowdrop the difference in panels is as much as 2" from side to side, with lots of gappimg all round. The front end of the bodyshell is also very ' gappy ', allowing water to run through the door sills / thresholds box section, they even made an allowance for this water to escape by leaving an indented section under the rear doors. The nearside sill / box section was seriously corroded internally, there is a double skin, rivetted together probably for strength, the top skin had all but disappeared with corrosion, but none of this was apparent from the outside. I have just made a new sill, and I am in the process of brazing in the collets / inserts for the carpet securing pins...more on that in a later ' Freewheel ' article. I bolted the body shell to a plumbed up wooden frame before working on the body to maintain rigidity, once off the chassis the body is quite ' flexible '
Hope that sheds a little light. Chris
