Points
SNOBHILL39
Points
Post by SNOBHILL39 » Fri Nov 09, 2012 4:03 pm
What do set plugs and points at, done the as per workshop manual and it runs awful.
Gerry F capon
Re: Points
Post by luli » Fri Nov 09, 2012 6:42 pm
Why do you suspect that the points are responsible for the awful running? are they new? have you measured the voltage drop on them when they are closed? the voltage drop on the coil primary when the points are closed?
MacKellaich
Re: Points
Post by MacKellaich » Thu Dec 06, 2012 4:06 pm
If you have put on a new set of points it is worth while giving the faces a roughing up with some emery. The points can have a coating on them and the spark across is not too great, this happened to me once?
SNOBHILL39
New look front grille
Post by SNOBHILL39 » Mon Dec 10, 2012 8:19 pm
Gerry F capon
