Carburation issues
Geoffrey
Carburation issues
Post by Geoffrey » Mon Feb 24, 2020 11:30 am
I am hoping someone has had a similar experience and found a fix. My car is a 1947 12 with the Solex downdraught carb. The car is fitted with an electric fuel pump.
Very intermittently it seems to suffer from complete fuel starvation. Typically I might pull away and the engine will then die on me. I drift into the side of the road. Wait a few seconds and the car will normally fire up again OK and proceed normally. Because I usually have the freewheel engaged when it does die there is no help from the rear wheels to get it going again. It seems most likely to happen after I have been waiting a while at a junction.
I think the little plunger thing that rests on the brass float occasionally gets stuck in the closed position. i.e. does not drop when the float drops causing the chamber to empty. This is really only a theory but I have noticed a slight tendency for it to stick closed when I have had the thing apart.
Any observations, cures or comments gratefully received!
Geoff
1947 Rover 12
1952 Sunbeam S8
Norton International Special
1957 AJS Model 20
1952 Velocette LE
2018 Royal Enfield Himalayan
1999 P38 Range Rover
Re: Carburation issues
Post by luli » Wed Feb 26, 2020 10:15 am
You can distinguish very easily if it is a vapor lock or a stuck needle valve. If the electric fuel pump is clicking like mad then it is a fuel starvation - most probably it is a vapour lock. If the pump does not click hit the carburetor with the adjustable ranch from the tool tray (or something similar). If the pump starts clicking, then it is the needle valve.
