Remote oil filters
Posted: Mon Jun 14, 2021 5:14 pm
by David2021
In the club workshop manual there is reference to the occasional fitting of a remote external oil filter to supplement the gauze strainer.
Does anyone have information about this? For a 1948 12 tourer.
I have found pictures & discussion on this topic from 2010 & 2016....has anyone done this more recently??
Re: Remote oil filters
Posted: Mon Jun 14, 2021 11:49 pm
by GOY189
David, as you may have seen, quite a complex subject.
AC ZS1 (Rover part no 216322) was fitted to 20hp saloons up to 1940 and was an option on other models. It was also fitted to Series 1 Land Rovers. Similar ones were fitted to MG TC/TD
See:-
https://www.johncraddockltd.co.uk/serie ... oil+filter
or
https://mg-parts.co.uk/index.php?route= ... l%20filter
or
https://www.mgexp.com/forum/t-series-an ... 5.4315836/
Posted: Tue Jun 15, 2021 7:46 am
See here a detailed description:
https://wp.me/pXLKy-1Wo
Posted: Tue Jun 15, 2021 10:51 pm
by David2021
Thanks I will check this out....meanwhile I have to find the existing mesh filter.....! The air filter was easy!
Posted: Wed Jun 16, 2021 8:20 pm
by GOY189
First, drain the oil. Look under the car at the offside of the sump. There is a large brass cover with a hexagon. Use the hexagon to unscrew the cover and withdraw it and the filter from the engine. You may be able to contrive a scraper to remove the crud from the sump. To clean the filter (really only a strainer) I used kerosene. A large container to hold the kero and filter helps with cleaning.
Posted: Wed Jun 16, 2021 10:24 pm
by David2021
Perfect...thanks!
Many questions to come as I get to know the car!
