Clutch, and steering box refurb
Willem
Post by Willem » Mon Oct 13, 2025 11:06 am
Good morning all,
Now the evenings are drawing in and the weather is less conjucive to driving a tourer I am gathering the knowledge to remove the clutch and steering box of my1936 tourer.
The steering box will go to Callum at c.barrow engineering to remove the play out of the steering.
As for the clutch, do I need any special tools to remove it and I assume it can be done with the engine in situ, are there any recommendations for clutch rebuilders?
I have a lift so access from below is not a problem and whilst things are dismantled I will also have a look at the freewheel, reverse does not engage when activated, that might be quite an interesting thing to do..
Any tips on the above are most welcome.
Will
Rover 12 Tourer, 1936
Range rover L322, 2009
Re: Clutch, and steering box refurb
Post by TonyG » Mon Oct 13, 2025 7:32 pm
Hi Willem,
A few thoughts that may be useful:
Gearbox and clutch - the gearbox will need to be removed from inside the car so the carpets, tunnel cover and front seats need to come out first. Then the pedals so the metal floor plate can be removed. Also the corresponding plate on the near side. It may also be necessary to remove some of the wooden floor panels to get access to the various nuts and bolts for the gearchange remote and rear gearbox mounting. The prop shaft also needs unbolting at the flange on the rear of gearbox. I think you can get to this with the centre tunnel left in place but you will want to roll the car back and forth to access the nuts and split pins. However, I have a feeling that the tunnel may need to come out so the prop can be moved out the way to allow the box to be withdrawn backwards, which may require handbrake removal. My apologies for being a bit vague but the last time I did this with TL 6200 was 1976 when my Father owned it. As I recall my brother and I completed the job in less than two days on the driveway. It can’t have been too complicated as we didn’t have a workshop manual in those days.
I took the engine and box out together when I restored it in 2015, which in some ways was easier but not necessary just for a clutch.
The speedo drive, clutch cable, Earth strap possibly and freewheel also need disconnecting. The latter feeds through the box and has a small bolt up sleeve on the cable, which must be removed to take the cable out. At this point you should have clear access around the bell housing to remove the starter motor and bell housing bolts. It will be necessary to support the rear of the engine and probably raise a little with a jack to allow the box to be separated from the engine and pulled backwards before struggling out the car with it!
There are two types of clutch and release bearing used on these models so make sure you have correct one to replace. You won’t know for sure which you have until you get to this point as it may or may not have been updated at an earlier time. My 36 Tourer had the later clutch assembly whereas my 37 Saloon had the earlier type. I think Meteor Spares do both sorts by exchange. There are many bolts holding the pressure plate onto the flywheel and several locating pegs. Loosen in rotation so the pressure stays even and remove.
Reassembly is the reverse of removal but you need to make a dolly of some sort to position and hold the clutch plate centrally or the gearbox input shaft won’t align easily. The release bearing must be checked. If it’s the later type these have large circlips holding them together, facilitating dismantling and re-greasing or even ball bearing replacement. The release bearing is lubricated on the shaft via oilways in the input shaft so worth checking these are clear and blocking one off if necessary to reduce oil flow if contamination is a problem. This is covered in the RSR manual.
I think that the freewheel won’t operate in reverse so the issue you have may be correct working. I’m not knowledgable on this as I rarely use mine.
Steering box - best removed while you have the floor plates out for the gearbox. The steering wheel needs to come off, which requires removing the horn and dip switch assembly. Take pictures of wiring as you dissemble so all goes back right. Once that bit is out the way you should be able to access through the hole the small bolt that holds the advance ring plate to the top of the tube. Then the steering wheel can be unclamped and removed. At the bottom of the steering box the horn/dip wiring can be disconnected at the small terminal box mounted on the chassis nearby and the advance/retard mechanism removed from the bottom of the tube. The drop arm/ball joint can be removed so the steering is free from the rods etc. There is a mounting bracket at the dashboard end of the column and two bolts near the actual box - one through the chassis and the other through to the bracket with the half moon slot, allowing adjustment of the steering column angle although I doubt anyone has ever done this! At this point the box and column can be removed, possibly through the car but probably from beneath. Once out the wiring can be withdrawn from inside the advance operating tube then the tube itself by undoing the four bolts at the bottom and withdrawing from that end. I believe there is a cork seal there that usually fails, resulting in the oil loss from the box so worth replacing at this point I should think.
I’d be really interested to know how you get on as I have got to take the steering box out of my car and get it looked at. I don’t have a lift though so I’m hoping it’s possible without one.
I hope that helps. It’s a very long time since I removed a gearbox through the car so I’m happy to stand corrected if I’ve missed anything and I’ve only removed and refitted a steering box as part of a full strip down of my cars when there was little bodywork in the way.
Good luck
Riley
Post by Riley » Wed Apr 29, 2026 11:59 pm
Morning Will,
Sounds like a great winter project 👍
On those older setups, you can usually do the clutch with the engine in place, especially since you’ve got a lift, that’ll make life much easier. You generally won’t need anything too exotic tool-wise, but an alignment tool for refitting the clutch plate is definitely recommended to save a lot of hassle.
While you’re in there, it’s a good shout checking the freewheel too, those mechanisms can get a bit temperamental over time, especially if they haven’t been used regularly.
For rebuilders, it’s worth looking for classic clutch specialists rather than modern garages, they’re much more familiar with refurbishing original components instead of just replacing them.
Willem
Post by Willem » Fri May 01, 2026 10:38 am
Morning Riley,
I'm collecting the last bits on Saturday so I can get everything back together again.
The freewheel needed some attention, there was a a bit of an oil leak from the output shaft, the cork seal had perished, now no longer available, the freewheel housing has now been reworked to accept a lip seal, that should future proof things a bit.
I removed the gearbox and bell housing but in order to get it out most of the interior has been removed.
It has been an interesting excercise so far,it has increased my knowledge of the car no end..
Will report back when things are back up and running, looking forward to that.
Willem
Willem
Post by Willem » Mon Jun 08, 2026 10:56 am
I reassembled the car and I am seriously looking to pull the clutch out again, when I first started the car and depressed the clutch there was an almighty racket (rythmic thumping sound) and the engine stalled. Loosening the clutch cable to a very slack state has now reduced the noise to a very faint ticking when the clutch pedal is fully down but I am not happy with that.
The freewheel is now working perfectly and reverse is now availble wheather in fixed of freewheel mode.
A bit of a bore having to pull everything out again but I do dislike funny noises, they rarely go away and usually indicate something is not quite right.
Will report back..
Post by SHyslop » Tue Jun 09, 2026 1:05 pm
Dear Willem,
I can only speculate based on my own experience two years ago replacing the clutch in my 1935 12 sports saloon. Now, your symptoms are different from what mine were because my clutch wouldn't disengage, once reassembled. Having had it to bits and back together in a week then apart again the next week, I was taking no chances on it not working the next time so I reused the original pressure plate, which gave every appearance of being satisfactory, and selected another new clutch plate which was minimally thinner. I did start to write about the variations in clutch plates but most of it is in the WSM which also details what modifications are required to fit later clutch components.
What is not clear from the 34-38 parts list is that although the one clutch plate is shown as fitting all these models, it is actually the 46/47 plate which requires the aforesaid modifications. In common with a number of Coventry makers, the loss of their prewar spare parts stocks meant that they either had to reverse engineer components or modify 1946 on parts to fit. Also, the detail applications did change during the period and the Raybestos catalogue of the time mentions that although 3/RV/1 linings fit most 34-38 models, "something else" appears to have been used in some models which have a "special assembly" fitted. Unfortunately, there was no further detail as to what that is or was.
The RSR workshop manual gives details on what is required to use a 46/47 plate in these cars but I wonder whether you had a plate relined , or an exchange plate. I thought at first the ticking could be one of the declutching levers touching the release bearing as the assembly rotates but that doesn't tally precisely with what you have said so I am left a bit stumped. Was your car still fitted with a four lever pressure plate and the release bearing consisting of a collar with two sets of ball bearings , or had it been replaced with the later types? The release bearing with the two separate rows of balls can be taken apart and lubricated, or the balls replaced as well.
Probably the above is not much of a help but one of these things where the answer probably lies in the detail of it all and without knowing that detail, there could be little to do but look forward to taking it apart again, but do make a careful examination of everything before doing so as it can be strange what causes dreadful noises. I had a noise yesterday but it was a bonnet stay on a ball joint that comes apart due to wear and then falls onto and vibrates on the rocker cover. I hadn't had the car out in over a year and feared the worst from the ominous rattle but once I saw it, I remembered thinking "I must fix that ball joint properly" and now the dreadful noise has gone. I hope yours may turn out to be equally simple.
Willem
Post by Willem » Wed Jun 10, 2026 10:25 am
Dear SH,
thank you for your reply, here are the details, all exchange parts are from Mike Couldry
3 lever clutch, exchange levers
Pressure plate, exchange
Spigot release bearing, exchange
Springs on levers, new
Flywheel pilot earing, new
I did notice that the exchange clutch plate is a bit thicker than the old one, stupidly I didn't take any measurements.
I did see in the WSM that the bolts can interfere with the clutch plate if it's from a LR series 1.
I am curious if there is any scoring on the clutch plate or else where.
Hopefully I'll have some time this weekend to look at it.
Post by SHyslop » Thu Jun 11, 2026 2:05 pm
Dear Willem,
I would be very hopeful that the cause of the problem will be reasonably apparent once a very close look at all the dimensions is made. I was just thinking, something I am finding increasingly useful, is one of those endoscope cameras you can now buy for reasonable money, although mine was a Christmas present from my sister in law.
It enables you to see into places such as the bellhousing through the oval plate on the top, or tappet chests to find nuts that drop in and the like. What prompted this thought was that, before you take it apart again, it would have been useful to try and ascertain where the release fork is sitting when the clutch pedal is both up and down. Of course, this is not so easily done once the gearbox is out but if you knew that measurement when it is assembled, maybe you would be in a better position to try and work out what component which is rotating is catching a static part to make the tick, and I am thinking that the fingers and the fork are potentially prime suspects - but this is armchair diagnosis !
It is brake linings I have found to be culprits for being overly thick when relined with bonded linings. These have defeated the previous owners of a couple of cars that have come my way, with handbrakes disconnected in the vain attempt to release the hold the brakes have on the rear drums, with the adjusters fully back. It will be very useful to hear what you find and I am reliving in my mind taking it all apart again - unfortunately, so you have my sympathy. (I saw I had mistakenly said "Sumpathy" and then thought that is maybe what we feel for a fellow car owner having to do work in the area of the engine.)
