1939 P2 R10 starter motor
ANDY
Post by ANDY » Sat Jul 11, 2026 1:17 pm
Having sorted my steering problem I can't start the car, the starter motor runs but does not engage. I've taken the motor out and everything seems to work. Powered up on the bench the dog flies out and returns when powered off. I've read posts that suggest moving the motor further forward but that doesn't work so I return it to its correct position with the locating screw and it still won't engage.
Any idea's?
Andy
Re: 1939 P2 R10 starter motor
Post by TonyG » Sat Jul 11, 2026 6:42 pm
Andy,
I can’t remember exactly, but there is a rubber interface (steel outer) as part of the starter drive. If this unit is perished the rubber no longer grips the steel and the starter doesn’t engage. However, on the bench the motor may appear to be working as there is no load on it to facilitate the slipping. I hope that my memory isn’t too far out and that my description makes sense!
If this is the problem, Mike Evans at Viking or Mike Couldry at Meteor should be able to supply the part. Of course, it could be something else but that would be the first place I’d look.
Hope that helps.
Post by SHyslop » Sun Jul 12, 2026 11:10 am
Dear Andy,
In addition to the excellent advice from Tony, can I add that the sleeve is also available from John Wearing who also say they make them, or have them made exclusively - photo of their part below :
https://www.johnwearingp4parts.co.uk/pr ... rod=260046
When you take the starter apart (which is straightforward), could I ask you please to check something and let me know. The rubber in the sleeve is indeed one reason why the starter fails to engage but it can also be that the two metal prongs on the inner sleeve can break off while the rubber is still in good shape. I would be interested to know what has happened to your particular sleeve. Thank you.
ANDY
Post by ANDY » Mon Jul 20, 2026 10:48 am
Many thanks for your replies and advice. I think the rubber was ok but I can't be certain, there was no return spring (gone) and it seems the key had failed (bits fell out) In the end I took the easy way out and went for a service exchange. It took less than half an hour to fit and started instantly, I'll settle for that. Thanks again.
Andy
Post by SHyslop » Tue Jul 21, 2026 1:46 pm
Dear Andy,
That is very good of you to let us know the outcome. If it is some slight consolation, I bought a 1926 car from a (then) well known specialist in the make and after the delivery driver had left, I went to start the car and the starter literally fell into about 15 pieces! Fortunately, I was able to buy a new Denso based starter for the model from AES, which gets us to the Rover bit. I appreciate you are sorted with a starter for hopefully a long time, but I have wondered whether this :
https://www.autoelectricsupplies.co.uk/ ... er-1948-54
would fit the 34-47 cars?
It would need the aluminium housing on the engine for the starter removed but after that it should be ok, in theory. I wonder if anyone has tried one and whether this is indeed the case?
There seem to be plenty of reconditioned and reconditionable original type starter motors on the go but it all depends on the work guaranteed to have been done and the warranty being provided. One of my autumn missions is to take them all out and examine the sleeve, pinion and brushes then give the commutators a clean. You have spurred me on to make sure I don't leave this undone !
