A new question about the sunroof
Posted: Fri Jun 08, 2012 4:46 am
by SA103
Particularly to Mike, who replied to my earlier question about the sunroof rear cover panel. I've a couple of specific questions about the rear cover:
1) Do you know the thickness of the steel sheet used? I'm guessing somewhere around 2mm - I haven't anything to judge this by.
2) What is the spacing and pattern of the 2mm holes? ie 50 x 50mm square pattern - or similar description
3)What are the size and number of the reinforcing pieces - it looks as though there are two - are they the same guage as the sheet - ie about 2mm
Thanks - this will help me no end - I think I am better off not guessing too much.
Best Regards
Adrian
Re: A new question about the sunroof
Posted: Fri Jun 08, 2012 8:13 pm
by GOY189
Hello Adrian, sorry about the delayed reply.
It will take me a little while to get to the sunroof to take the measurements, but I will asap.
Posted: Sat Jun 09, 2012 5:49 am
by SA103
Hi Mike
Thanks for that...will patiently await your reply
Adrian
