My P3 has a lean to the right. I suspect a broken or worn spring. I'm about to separate chassis from body to restore the chassis and running gear. Spoke to a spring manufacturer about resetting the springs, or getting new ones made. I have the data for the front springs but not for the rear. I need to know the 'camber' of the rear spring, the vertical distance between the axle tube locating plate and either the centre of the shackle eye or the bottom of the shackle eye. I believe old English cars measure from the bottom of the shackle eye, although I could be wrong.
Grateful if you could offer some assistance.
Regards, Al
						P3 Spring data
Re: P3 Spring data
Hi, any one here can help me with the details on the rear springs, with measurements etc.
thanks
Kartik
						thanks
Kartik
