How to raise the P3 from the front.
Posted: Sat Jan 13, 2018 5:50 am
by kartik
Hi
the front of my rover p3 1948 droops from the front, instead of a straight line it should be in,
is it because of the front coil springs, or are we doing something wrong.
Is there a padding which goes under the front coil springs to raise the car from the front.
Please see this link to see my car
http://www.team-bhp.com/forum/post-war/ ... ost3881716
thanks
Kartik
Re: How to raise the P3 from the front.
Posted: Sun Jan 21, 2018 12:21 pm
by Phil - Nottingham
Nicely done P3 indeed
It is a little low but sometimes excessive camber on the rear can affect the front. It certainly does so on P4's. I am not familiar with P3's just P2/P4/P5 though.
Packers could be fitted as they are in P4's I suppose but the coil springs could be tired
Welcome to the forum as well
Posted: Mon Jan 22, 2018 7:43 am
by kartik
Thank you , will have a re look at the front coil springs and see if it makes a difference,
what kind of packers can be used under the springs ?
Posted: Wed Jul 04, 2018 7:21 am
by jp928
I suspect the rear springs are set too high. Phile suggested excessive camber at the rear - difficult to get camber on a live rear axle isnt it? Lovely piece of work , good to see.
jp 26 Rover 9
Posted: Sat Jul 14, 2018 8:21 am
Obviously,
I meant excessive camber of the rear spring ie to much curve
Posted: Sun Jul 22, 2018 3:50 am
by jp928
Some Bentleys with heavy bodywork were prone to bending of the rear axle producing negative camber, so they started making the axles with positive camber to compensate, I have read.
Are all the front end suspension bushes in good shape? As I recall these bushes were quite small in diameter - maybe 1/2" ID and 1" OD - and wore quite quickly - too soft?
jp 26 Rover 9, previously P2,P3,P4,P6,P6B,RR,Disco
