Starter Motor
Posted: Sat Sep 17, 2011 3:53 pm
Hi
Does anyone have an assembly diagram for the starter motor on a P3? Mine is marked up 'LUCAS M418G G76' I can find lots of info on the type that throw the pinion 'forwards' ie, towards the front of the car but nothing useful for my type which throws the pinion backwards.
Mine works fine most of the time and is perfectly free running but doesn't always engage the pinion. It seems to have 'disappeared' the light return spring which pushes the actual pinion back onto the bendix spiral and I think keeps the inner part of the Bendix engaged on the lugs of the shock absorber unit. Add to that, I'm not sure it has been assembled in the right order.
The bit I need the information on is the 'Bendix' layout and assembly, better still, someone who has a fully functional version and can post a picture.
Ta - in anticipation
Willum
Willum
