Windscreen wipers suddenly don't work!
				classicclara
Hi. Can someone advise please - the windscreen wipers are no longer working/moving when the switch on our P4 95 is put on. What's the problem? Thanks in advance! Rebecca
						- Phil - Nottingham
Re: Windscreen wipers suddenly don't work!
Could be just connections on the switch or motor with the aid of the wiring diagram test for feeds and earth continuity. Alternatively motor/rack could have seized (lubricate) or burnt out as could switch but not likely
Hi check your fuse first or could be the earth which I think is next to the motor onto the bulk head
