Rover P4 diffs
andy80
Rover P4 diffs
Post by andy80 » Thu May 06, 2010 7:55 pm
Hi....I've been looking into Rover P4 diffrentail ratio's, Am i right to say that there available in both 4.1-1 & 4.3-1 ratio's??????
Paul Gregory
Re: Rover P4 diffs
Post by Paul Gregory » Fri May 07, 2010 9:20 am
Hi Andy,
The majority of P4's have a 4.3:1 ratio diff but there are some with 3.9:1 (non overdrive 90's and all 95's) and I think that some 60's were fitted with 4.7:1.
The 4.7:1 was also fitted to the majority of Series 1, 2 & 3 Land Rovers
I believe that in general the P5 also had 4.3:1 but again some were fitted with 3.9:1
The P5B was fitted with a 3.5:1 as was the original Range Rover, Discovery 1 and relatively early coil sprung 90's & 110 LR's.
These are all interchangeable I believe there was a design change during later production of the 3.54:1 diff so I am not certain how interchangeable these later ones are, but the majority of them would fit.
Which P4 model are you thinking of changing the ratio in?
Paul
RSR Post 1950 Librarian
