Lucas Alto Horh-setting up
Posted: Fri Dec 26, 2008 3:56 pm
by DavidTayler
Does anyone have any instructions for setting up a Lucas Alto horn.I have dismantled mine and cleaned the contacts. It now makes a noise but there are several variables to adjust and there should be a logical way to do it. I have checked the workshop manual and it is not in there. Happy New Year to all. David
Re: Lucas Alto Horh-setting up
Posted: Tue Jan 01, 2013 8:42 pm
by chris dancey
Hi David,
I am sure I have somewhere, I will have a search and get back to you.
Regards, Chris
Posted: Tue Jan 01, 2013 8:59 pm
by chris dancey
Hi David, What I found was information attached to some horn gaskets I bought from a chap called Taff. He has a very compehensive website full of horn information.
His site is www. taffthehorns.com
Its very important to use exactly the same thickness gaskets, I impregnated mine with vaseline to help prevent them absorbing water, warming the gaskets to aid penetration. This is because dry gaskets absorb moisture.
I am sure an email to Taff will help solve the problem. Best of Luck.
Chris
