Long lost Photo
Posted: Mon Aug 08, 2011 11:41 pm
by brianswife
Can anyone help me with any information on this photo of a long lost relative.. What is the car and is it possible to trace name of owner through registration records! also any ideas of date of photo it looks late 40s early 50s.Thankyou.
Re: Long lost Photo
Posted: Tue Aug 09, 2011 2:52 pm
by paul williams
thanks for your enquiry, I may be able to help a little.
The car is a Morris 10 Series II or possibly a 16 or 18, it is hard to say without a side view. If the car has wire wheels which I think it does this would indicate it was made before 1936 when a change to metal easiclean wheels occurred. The large spotlamp is not original, having replaced a standard smaller item and also there used to be a horn on the opposite side. The plates added to the radiator are to increase heating by muffling the radiator, this was common in the 30/40s when drivers did not use antifreeze or wanted the car to warm up quicker. The reg no ATF50 is not registered on any car at present, so it is highly likely the car does not exist.
The extra badges show it may have belonged to a car club so I would suggest you contact a Morris owners club if you want more information about the car. Maybe the morris register http://www.morrisregister.co.uk
As for the date of the photo I think you may be correct, the car is well used, the roads are empty and no sign of TV aerials on the houses so 40/early 50s is a good guess.
I am not an expert on Morris cars and maybe wrong,I hope the above helps
Re: Long lost Photo
Posted: Wed Aug 10, 2011 3:59 am
by brianswife
Thankyou so much for your reply.. I thought it was a Rover.. you have been very helpfull i will try and find out his name from morris records.. I know hes a Great Uncle its just finding out which one.......... Thankyou again :D
Re: Long lost Photo
Posted: Thu Aug 11, 2011 7:09 pm
by andrewmcg
Hi there
I agree with Paul's comments and can further add that according to my old copy Glass's index of vehicle registration numbers the Reg prefix ATF was issued by the Lancashire licensing authorities between Feb and Apr 1936, and the low number of 50 would probably indicate the early part of the run.
Good luck with your enquiries via the Morris register.
Andrew
Re: Long lost Photo
Posted: Tue Aug 16, 2011 12:01 pm
by brianswife
Thankyou both.... I have to pay to join the Morris Club so i give up... Was worth a go and i appriciate all the help!
