P6B NADA spec RH door mirror wanted
Posted: Mon Nov 03, 2008 10:06 pm
by patrick hiron
Hi
I need a Paddle shaped door mirror for the RHSide a 1970 NADA spec P6B . I'm not sure if these are handed or if one mirror fits both sides . My RH door is predrilled for the Rover mirror, which is held on by self tapping screws Tthe holes are presently plugged with little plastic buttons . The fixing holes centre to centre distance is 43/8inches
As A alternative I would be interested in acquiring a matching pair of Rover mirrors with the same fixing dimenions .
The NADA spec door is full of complex trim , anti intrusion beams , electric window mechanisms etc so I don't want to strip the door to deal with nut and bolt fixings !!
Patrick
Re: P6B NADA spec RH door mirror wanted
Posted: Tue Nov 04, 2008 2:19 am
by Dirkco
Hi Patrick,
Either send a picture of the mirror to my email you have or post a picture. I most likly have a mirror for you and will be happy to donate it to the cause.
By the way the white wall tires you put on your P3 were they radials from Coker tire? If so what size did you use?
Hope you are well
Dirk
Posted: Wed Nov 05, 2008 5:28 pm
by patrick hiron
Dirk
Thanks for the offer . I will e mail you a picture of the mirror . Please advise your e mail address , my computer died recently burying all my e mail records
IKB had a set of Firestone white wall cross plies .They were almost unworn , except for the spare which was an original Indian retread ! I debated fitting radials but concluded that the main function of P3 tyres is to stop the rims and brake drums from running on the road and it wasn't worth the cost to go to radials .
Cheers
Patrick
Posted: Thu Nov 06, 2008 11:21 am
by Dirkco
Hello Patrick,
I sent you a aemail but it bounced back. You can send a picture to me at
Cars @roveramerica.com
Dirk
Posted: Mon Nov 10, 2008 2:30 am
by Dirkco
Hi Patrick,
i have tried several times to email you but it just keeps bouncing. Do you have another email address?
let me know
Dirk
Posted: Wed Nov 12, 2008 4:09 am
by patrick hiron
Dirk
Did you receive my e mail and pictures ?? my e mail phing@videotron.ca" target="_blank has been sanitised and is working
Cheers
Patrick
Posted: Thu Nov 13, 2008 1:59 am
by Dirkco
Yes,
I did recieve the pictures
Dirk
Posted: Thu Nov 13, 2008 4:33 pm
by patrick hiron
Dirk /\, Sorryto communicate by Forum ! Do you have a suitable mirror in your inventory ??
Patrick
