new radiator/recore for p3/75
Can any one in australia help me in the right direction to procure the above at a reasonable price.thanks regards Derrick.Smith.
Re: new radiator/recore for p3/75
In which state you are living in Australia? Australia is a big country and what kind of work you want to do with your vehicle?
Thanks for your reply. i live in bundaberg queensland.it appears that i will need a complete recore.there are visible signs of corrosion build up in the tubes,and when they try to get rid of this i am afraid some of these tubes will leak.hence a the recore.regards Derrick.Smith.
Hello,
Is it worth trying Radweld before you go to the expense of a new radiator core? I am sure your local motor factors will be able to help/advise you
Rad weld is readily available in the UK, Try eBay
Cheers, Robert
Cheers, Robert
Thank you robert for your very much appreciated.regards Derrick.
