Smiths water temperature gauge
Posted: Fri May 29, 2009 1:19 pm
This working gauge was taken from a pre-1939 Rover where it had been fitted as an accessory. It has a chromed bezel and 1.8m of capillary tubing and is calibrated from 90 - 212 degs. Fahrenheit. It is the same size as the Jaeger oil pressure gauge, 51.7mm in diameter. I have fitted one of these to my 1936 tourer by cutting a hole in the dashboard. The bulb fits into the thermostat housing, with an adaptor instead of the brass plug. I have advertised it elsewhere for £65.
