Oil Pump for late Rover 12
Post by chris dancey » Fri May 01, 2015 7:30 am
Hi Everyone, On behalf of a Rover owner down under who has nearly completed his engine rebuild, does anyone have a spare oil pump for sale ? His name is John Clement, he has tried the usual sources, but to no avail.
Please help if you can, Thanks,
Chris
Clem
Re: Oil Pump for late Rover 12
Post by Clem » Fri Jun 24, 2016 11:50 am
Just thought I'd let members know that by taking my knackered P2 oil pump and the guts from a relatively unworn P3/4 pump and getting a top class engineer to cut down the gears, rebush everything, make a new idler spindle and machine the baseplate flat again I now have a very effective oil pump. Quite a lot of engineering involved but at least a pump I can be sure of delivering enough flow for my new 12hp P2 engine. Regards John Clement Moonee Ponds Victoria Australia.
jp928
Post by jp928 » Sun Aug 07, 2016 1:15 am
I have to recommend this approach to all with parts problems. Rover didnt lightly change components radically in families of cars or engines, so it is likely that another model in a family will have parts that are close to what you need. In the 70s a gent with a 1933 14hp model (met previoulsy) asked if I could help him with a failed timing chain, and very worn cam wheel. I got a chain off the shelf readily! The crankshaft chain gear was same as a P3 IIRC. For the cam wheel, we found that a P3 unit was almost identical, just a bit thicker in the boss. After getting 1/4" machined off the rear face of the P3 wheel, it all went together.
jp Previously P2,P3,P4,P6,P6B, RR , Disco
Post by luli » Sun Aug 07, 2016 7:53 am
While the observation that Rover had been conservative in modifying their products is right - the conclusion is not always that they remained unchanged. P3 onward had in-line oil filter - absent in P2, P3 oil pump turns clockwise while P2 anti clockwise - which means different driving teeth wheel (both are available from Mike Couldry). It would be interesting to see a photo of your modified P3 pump.
Here is a description of reconditioning an original Rover 10 1947 oil pump: http://wp.me/pXLKy-272
