1939 14 Dipping Headlights
Colin
Post by Colin » Thu Nov 13, 2014 2:31 pm
I have wiring for dipping headlights - what do I need to purchase to fit the double filament bulbs into my headlamps? Should I fit Halogen bulbs? Has anyone done this?
Thanks in advance! Colin.
Re: 1939 14 Dipping Headlights
Post by luli » Thu Nov 13, 2014 9:01 pm
I had decided to sacrifice originality in sake of safety and installed halogen bulbs on both cars. Halogen gives almost three times the light of a regular bulb. It is designed for special reflector and lens which bears the “E” standard mark on it. It produces a “non-symmetrical” beam which may also contribute to safety. All that means that the original reflectors and lens need to be replaced in favor of a modern 7” set. Since the original MBD148 headlight is 7-13/16 in diameter, an adapter (convertor) has to be used. Lucas released such adapters – Lucas part number 553435. They are available, from time to time on ebay.
See more here: http://wp.me/pXLKy-1eS http://wp.me/pXLKy-1ff
Colin
Post by Colin » Fri Nov 14, 2014 10:42 am
Thanks Luli. Looks like a nice set up. If I went for non Halogens, is there a way to get the double filament bulbs into my existing lights?
Post by luli » Fri Nov 14, 2014 1:47 pm
You need to replace the single contact bulb holder with a double contact one. You can get it here:
http://www.vintagecarparts.co.uk/produc ... ulb-holder
And of course, you need to replace the bulbs too...
http://www.vintagecarparts.co.uk/produc ... -lamp-bulb
Colin
Post by Colin » Fri Nov 14, 2014 2:54 pm
Perfect. Thanks - I have ordered some.
