SU Downdraft carburettor in place of Solex
Re: SU Downdraft carburettor in place of Solex
Post by luli » Mon May 30, 2022 8:58 pm
Try using a vacuum gauge and get best vacuum at 600 - 500 rpm.
Post by David2021 » Fri Jun 10, 2022 10:46 am
Thanks...will start there! Not going to try it until later...need to sort the overheating & the
trip to Germany (I hope...)
Post by luli » Fri Jun 10, 2022 12:00 pm
Make sure that the bi-starter is assembled correctly. This essential to get proper idle. Unfortunately, I found that in some 30FAI units some internal crack prevents this to happen (I have tested some 10 units and found that 3 of them have this). You can verify that when the "cold start" cable is fully in. Put your finger on the Air jet of the bi-starter and see if it makes any difference.
