flashicators!
MikeB
flashicators!
Post by MikeB » Fri Jan 23, 2015 6:26 am
Here is a supplier of led bulbs to convert your trafficators into flashicators !, about to purchase a pair of bulbs,however took mine out and cannot find them, vendor needs to know if they are 6mm or 7 mm my car is a 39 p2 has anybody tried theses and do you know the size of bulb length on the trafficators for 39 car ?
MikeB
Re: flasicators !
Post by MikeB » Fri Jan 23, 2015 6:27 am
MikeB
Re: flasicators !
Post by MikeB » Fri Jan 23, 2015 6:30 am
Re: flasicators !
Post by luli » Fri Jan 23, 2015 7:45 am
Which type of traficators do you have? Rover had used at least 4 different types (see here http://wp.me/pXLKy-qE ) - but on most 7 mm bulbs are OK.
Note that Rover P2 is a positive ground car, and the electronic regulator is for negative ground only – however reversing the polarity is not a big deal. I have tested that electronic regulator briefly – and it works. See more here: http://wp.me/pXLKy-2hc and here: http://wp.me/pXLKy-16l
