1935 14 rear hub oil seal
Arewethereyet
Post by Arewethereyet » Sat Nov 12, 2016 4:58 pm
My offside rear hub appears to have a leaking oil seal, any ideas of price/ availability/ options of alternative model fit items? Cheers, Mark
Re: 1935 14 rear hub oil seal
Post by 47p2 » Sat Nov 12, 2016 6:42 pm
Two things to check before replacing the seal.
First check the diff breather isn't blocked as this can cause too much pressure and blow oil past the seal, second check the oil level in the diff isn't overfilled (doesn't take much) as the extra oil will push out past the seal.
Arewethereyet
Post by Arewethereyet » Sun Nov 13, 2016 7:58 pm
Well, removed rear seat, no breather apparent, just small square headed plug on top of diff. Would Land Rover one fit?
Post by GOY189 » Sun Nov 20, 2016 1:47 am
That part number 3289 (1936 on diffs) supersedes to FTC3670 which is a swivel housing plug on most modern landrover vehicles, Srs one to date.
The Land Rover axle breather, part 515845 fits P4, P5, possibly P6 and Land Rovers from 1960 on.and has a much smaller diameter thread.
You could buy an FTC 3670 and drill and tap it to take 515845. Parts should cost under £10
Arewethereyet
Post by Arewethereyet » Sun Nov 20, 2016 9:16 am
Many thanks Mike, mines definitely a 6 spline axle. There was an audible "hiss" when I removed the top filler plug, so it's pressurising.
I'll try the drilled/ tapped / series breather option I think, seems a neat solution.
Post by GOY189 » Sun Nov 20, 2016 11:50 pm
Further information from a Land Rover owner suggests that the breather may fit the threaded hole in the diff. It looks a lot smaller in the available pictures.
