Door hinges
MarkK
Door hinges
Post by MarkK » Mon Apr 17, 2017 4:44 pm
Is door hinge wear/alignment taken up by adjusting the hinge pins?
I have a low mileage 10hp with new hinge pins and not much wear where it might be expected but two of the doors are 'wobbly' when closed.
Thank you.
Mark (1947 10hp)
Chris C
Re: Door hinges
Post by Chris C » Mon Apr 17, 2017 6:53 pm
Hi Mark, The play in the door hinges is caused by worn "acorns" which are small acorn shaped items between the top and bottom hinges.
There are various shaped acorns, some are curved top & bottom and some are curved at one end and tapered at the other end.
Normally the pin (bolt) does not wear. You can get replacement ones from Paul Beck / Vintage Car Parts
https://www.vintagecarparts.co.uk/parts ... -and-balls
You may need to "fettle" them to fit correctly.
Rover Sport Register
1939 - Rover 14 Saloon (P2)
1975 - Rover 2200 Saloon (P6)
Re: Door hinges
Post by luli » Mon Apr 17, 2017 10:57 pm
I had got mine from Mike Couldry. See pictures here http://wp.me/pXLKy-1bJ and also here http://wp.me/pXLKy-Bq
MarkK
Re: Door hinges
Post by MarkK » Tue Apr 18, 2017 2:44 pm
Thank you gentlemen.
