Vacuum Advance Mechanism components
Ray
Post by Ray » Thu May 21, 2020 9:31 am
Does anyone have a picture of the Vacuum Advance Mechanism components on the 1949 Rover P3 distributor.
Re: Vacuum Advance Mechanism components
Post by GOY189 » Thu May 21, 2020 3:02 pm
Would that be a Rover 60 or a Rover 75? 4 cylinder cars (Rover 60) use part 261489 - same as Series 1 Land Rover
Ray
Post by Ray » Thu May 21, 2020 3:38 pm
Hi, thank you for your response.
It's a 75
Regards, Ray
Post by GOY189 » Thu May 21, 2020 4:26 pm
The P3 75 vacuum advance is Lucas part 424625 according to the Lucas distributor cataolgue. If you are looking to obtain one, can I suggest the distributor doctor in the UK?
Best regards
Ray
Post by Ray » Thu May 21, 2020 4:55 pm
I have the parts for the mechanism but I am not sure how they go together.
I am after a picture or exploded view of these parts as they would be if you could see inside the barrel of the distributor.
There is a heavy spring, a light spring, one hollow piece of brass, one solid piece of brass, a thumb screw assembly and the diaphragm.
There were also five washers under the large nut which screws into the Diaphragm Housing but I don't think they were supposed to be there.
The Distributor Doctor said he doesn't have a picture.
I hope this makes sense.
Regards.
Ray Lilly
MaxPegler
Post by MaxPegler » Fri May 22, 2020 5:58 am
Have you got the RSR Parts Manual. there's an exploded view in there that should help.
Max P
Ray
Post by Ray » Fri May 22, 2020 7:16 am
I have the RSR Manual but I can only find the exploded view of the distributor on Page J4.
This does not show the detail of the parts I mentioned previously.
Please let me know the page number if I have missed the exploded view you are referring to.
Regards,
Ray Lilly
Post by GOY189 » Sat May 23, 2020 11:20 am
Hi I can't find the exact model but there are plenty of exploded diagrams on the net .
There are general views of Lucas distributors
here:- https://www.uniquecarsandparts.com.au/h ... istributor
and here https://mossmotors.com/mgb-25d4-distributor-1962-74
Hope this all helps
