P3 75 low oil pressure
MikeCarp
Post by MikeCarp » Sun Apr 06, 2025 2:01 pm
I have a 1948 P3 75. When starting the engine from cold the oil pressure is about 40 when idling and revving the engine. For the first half hour the oil pressure remains at about 40 both when driving and idling. After half an hour the oil pressure starts falling, so that after an hour the pressure is about 5 - 10 when idling and about 15 - 20 at 35 mph in top gear. The engine runs fine even after an hour and the temperature remains steady at about 77 degrees. The bearings have been checked an are OK. I have two questions:
1. Does anyone know what might be causing this fall in oil pressure and a remedy?
2. Is it potentially damaging the engine if it is driven with this low oil pressure?
Thanks for any responses.
Mike C
Re: P3 75 low oil pressure
Post by GOY189 » Thu Apr 10, 2025 4:59 pm
What grade of oil are you using?
MikeCarp
Post by MikeCarp » Thu May 01, 2025 4:32 pm
I'm using Castrol Classic GP50 oil.
