Removing P2 sump
Removing P2 sump
Post by RobHomewood » Sun Jul 01, 2018 5:47 pm
I am trying to remove the sump (engine in situ) to clean it out. So I drained it and removed the oil filter and all the nuts and bolts but it is solid. The sump flange sits in a lip of the block and so there is no place to get a purchase. Tried tapping with a soft mallet but no movement. Has anyone got any suggestions please?
Re: Removing P2 sump
Post by luli » Mon Jul 02, 2018 5:31 pm
The gasket is most probably glued to both engine and sump. Cut through the glue using a knife, sharp screw driver etc. Then use the screw driver as a lever.
Post by RobHomewood » Tue Jul 03, 2018 11:19 am
Thanks Luli
I will try again to cut the bond although the flange blocks direct access
Post by RobHomewood » Tue Jul 03, 2018 3:28 pm
Thanks again Luli
Having cleaned up the excess gasket and got my new inspection lamp under the car I could see that I was not attacking the correct joint and following that the old chisel did a straighforward job of breaking the seal on the sump. Now the joy of cleaning it!
