Rover P3 Distributor
I need to know how to secure the Distributor in a P3, is there a Clamp
or some other fixture to secure the distributor.
can any one please upload picture of the distributor/engine area.
thanks in advance
Kartik
thanks in advance
Kartik
				lakesrally
Re: Rover P3 Distributor
Hi, there is a clamp but I am away from home at the moment and cannot take a picture for you.  I'm sure someone else can post a picture before I get home at the end of next week, if nobody has posted by then let me know and I'll take a photo for you.
				lakesrally
Hi John, I'm not sure to be  honest, if you post a picture I can tell you if it looks anything like mine.
Hi ,the dist. on p-3 is diffrent from the p-2 it has vacum advance .
Moshe from Israel.
						Moshe from Israel.
The P2 has an alloy spacer between the engine block and the distributor, at the top of the distributor there is a clamp which can be seen in the images. This clamp has an adjustable thumbscrew for advancing/retarding the ignition without undoing the clamp. Hope this helps, maybe Stewart can confirm if the P3 is the same set up
				lakesrally
No, it's different.  I hope to be home tomorrow night but the P3 is not at home.  I'll try to get to the barn it is in over the weekend and take a picture.
				lakesrally
Hi Kartik, here are three views of the clamp in-situ on the car.  To give you any more detail will require me taking the distributor and clamp off the car, which I will do if required but I'd rather not as I am bound to end up with problems getting the timing right again.
Stewart
Thank you so much, I hope we would manage with these pictures.
Kartik
Kartik
