Engine Fault
rgall17263
Engine Fault
Post by rgall17263 » Sun May 11, 2014 4:25 pm
I cannot get my 1935 Rover P1 to start I am getting a good spark and fuel, timing is spot on, it will start for a few seconds and cut out what can be wrong with it any help
Re: Engine Fault
Post by GOY189 » Sun May 11, 2014 10:41 pm
Have you tried substituting the condenser (not an easy task I know. but it may be the source of the problem). The other suspects could be any new ignition components - new rotor arms can sometimes fail.
rgall17263
Re: Engine Fault
Post by rgall17263 » Mon May 12, 2014 7:40 am
Thanks Mike but I have renewed all ignition parts and condenser
Richard
paul williams
Re: Engine Fault
Post by paul williams » Mon May 12, 2014 6:21 pm
a few things to check, you probably have already:
Is the air intake clear - try starting without air filter
Is the exhaust blocked?
Is it good petrol?
Does it run if you squirt one of those easystart aerosols in the carb?
Is the dynamo seized?
Do you know the history of the engine, has it been running OK recently? Any more info would help
Paul Williams
1929 2litre Saloon
1934 P1 10HP
1951 Rover Cyclops
1974 P6 3500
1998 LR Discovery I
rgall17263
Re: Engine Fault
Post by rgall17263 » Mon May 12, 2014 10:35 pm
The car was running perfect until a couple of months ago then it would not start
Tried it with and with out the filter on
Petrol good
Dynamo not seized
I do not think the exhaust is blocked
I will try easy start
Any one else got any idea it is the 6 cylinder engine
chris dancey
Re: Engine Fault
Post by chris dancey » Tue May 13, 2014 2:37 am
I would suggest that you check the following.
1) Is there a spark on each plug. Remove each plug in turn, place back on the lead and hold near the block . Get someone to turn the engine over by the starter, if no spark on any plug then the coil is suspect. If one plug only does not spark, then suspect the plug leads, terminal cap of maybe the leads/cap/terminal are arching/shorting to the cylinder head. If using the brass solder on type terminals, cover them with shrink wrap to prevent shorting to the block..or each other plug.
2) Suspect the distributor cap, points, condenser as afore mentioned, use only the red rotor arms available from the distributor doctor, the rest are usually made in China and can fail.
3 ) Do you have adequate fuel..if not suspect the fuel pump.
4) Is the carburettor jet blocked, and does the piston slide freely ?
Have you altered the timing recently ? The timing marks on the flywheel can be out of synch. Often in the past ( due to wear or damage on the starting ring ) the flywheel would be turned round to a fresh segment of the ring and the timing marks would no longer apply.
If all these have been checked, let me know..I still suspect the coil may be the first item to look at ( Item 1 )
rgall17263
Re: Engine Fault
Post by rgall17263 » Thu May 15, 2014 5:13 pm
Thanks Chris
Were is the best place to get genuine Rover parts i.e. red rotor arm and distributor cap I suspect the ones I have a from China
I personal think its a fuel problem
jefflee
Re: Engine Fault
Post by jefflee » Sun May 18, 2014 8:54 pm
HI,
I HAVE HAD A SIMILAR THING HAPPEN,THE CORKS ON THE RESERVE TAP ARE A REGULAR SOURCE OF AIR INGRES ALLOWING FUEL STARVATION,
A PLASTIC MILK BOTTLE, GOOD PETROL AND A PIECE OF RUBBER HOSE COUPLED TO THE PUMP SUCTION WILL ILLIMINATE A FAULTY FUEL LINE.
HOPE THIS HELPS.
JEFF.
rgall17263
Re: Engine Fault
Post by rgall17263 » Mon May 26, 2014 3:45 pm
Can any help where can I buy genuine Rover parts I need a condenser, points and a rotor arm
Re: Engine Fault
Post by 47p2 » Mon May 26, 2014 4:13 pm
Try the Distributor Doctor
Click for link
